Home > General > Towbar wiring
Simonhunt72
Towbar wiring
Hey all , hope I'm posting in the correct place , well finally landed my rrs , a 4.2 supercharger 2006 , lovely vehicle, loves the rain as it stops the parking sensors working Haha, anyway , the post is about towbar wiring! It has 12n already but no12s ,is it a simple add or complex , happy to do it myself , but not sure on a starting point, thanks in advance
Post #582756 Thu Jun 20 2019 9:52pm
samd
Here's your instructions:
[http://www.rydertowing.co.uk/towbar-wiring/12s]
13 pin is much better, however.
Post #582758 Thu Jun 20 2019 10:12pm
Have a look at the top of the maintenance sub forum.
Post #582762 Thu Jun 20 2019 10:17pm
Simonhunt72
Thanks for replys
Post #582768 Thu Jun 20 2019 11:11pm
Simonhunt72
Had a look at the diagrams and makes some sense , have land rover already put the connections there ? Or do I need to run cables 🤔
Post #582787 Fri Jun 21 2019 10:13am
cables will either be inside behind the left light.
or as you already have 7 pin plug, they maybe outside, below the rear left light.
you could remove the rear left light and see if you can pear down and see any spare plugs
Post #582789 Fri Jun 21 2019 10:38am
Simonhunt72
Thanks Andy K ,will be looking this weekend , hope I can find them there !!
Post #583028 Tue Jun 25 2019 8:27pm
Simonhunt72
So , whilst I will be hoping to find the wiring for the 12s somewhere near the light unit , I will hope to look at sensors as well, as looked tonight and not one is clicking( dont think I'm that deaf) any ways of checking without bumpers off , or is that a given, have done the test,in reverse ,no p brake and button pressed to stop the flashing??!!
Post #583030 Tue Jun 25 2019 10:04pm
I don’t think button should be pressed.
Inspect wiring loom.
Do you get a noise from the rear when reverse is first selected?
A message on the dash about fronts?
Post #583031 Tue Jun 25 2019 10:14pm
Simonhunt72
Tried both ways with red led both flashing and off, nothing on dash, and nothing in reverse , just long high beep on ignition!!
Post #583034 Tue Jun 25 2019 10:20pm
