![]() | Home > General > EAS fault need advice please |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
I think you need the DTCs read. Can you hear the air compressor running a lot? You may not leak air from the air springs or even the tank but if the comp is worn and runs a lot more to compensate, this can also give you a warning. Jacking the vehicle should make no difference, my car settles back to normal as soon as I’ve moved it (allowing the suspension to move back to rest). 2019 5.0 SC SVA (Current)
| Titch Member Since: 09 Sep 2018 Location: Gloucester Posts: 12
Thank you |
Is there anyone in Gloucester who could read my codes?
It’s well worth buying an IID tool and will probably pay its way in no time. I’ve got SDD which is very in depth and will do things the IID tool can’t, however the IID tool is so much easier to use that I use it often. SDD can take about 10 minutes to setup but IID is more like 10 seconds. 2019 5.0 SC SVA (Current)
Thank you |
| 03184 Member Since: 11 Jul 2018 Location: Alicante Posts: 63
Titch, if you can't warrant getting an IIDTool, the cost it would take for someone to come around to read the codes, you are better off spending that money on an ODB reader from icarsoft etc. For sure you will get issues in the future and you dont want to be paying out again for someone. RRS 2006 2.7TD BLACK (MY FIRST RR!!!!)
Thanks for that, and listening to others i have decided to splash out and get a Hawkeye, so hopefully save some cash along the way. I agree totally as i do not intend on getting rid of my RRS as it only has 50,000 miles on it. |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Jacking doesn't make any difference.
I have changed the rear right height sensor but the on board display shows the car is level. |
| rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109
Needs calibration when you change a sensor |
| All times are GMT |
