Home > Maintenance & Modifications > Brembro break disks 380mm
Buster007
Minefield out there when it comes to break disks. I’m upgrading the four pot callipers to the bigger 6 pot on my SDV6 2012 Obviously I need to put the bigger 380mm disks on. Should I fit OEM LR disks or go for Brembro? There are loads availability on eBay what’s the difference? are all brembro the same or are there differences? Are drilled worth getting or just standard can anybody recommend a set please? Banging Head Cheers Laurence.
Post #582302 Thu Jun 13 2019 8:23am
Buster007
So this is where I might be getting confused I need to know the model number of the 2012 Supercharged RRS? Mine is the SDV6 which is a L322 model? What’s the model of the S/C because I’m upgrading to those brakes. Cheers Laurence.
Post #582316 Thu Jun 13 2019 10:29am
If you have a Sport it is a L320 irrespective of which engine is fitted, a L322 is a fullfat
Post #582327 Thu Jun 13 2019 11:21am
Brit Plumber
My Original Land Rover discs have the word brembo dot stamped on them so if you see the original brembo discs cheaper than at LR, buy them. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #582346 Thu Jun 13 2019 4:25pm
Don't think this is a bad price for genuine L/R discs, not sure my original discs had Brembo stamped on them, the genuine replacements from L/R certainly didn't.
https://www.ebay.co.uk/itm/Range-Rover-L40...SwckVcUIoC
Post #582366 Thu Jun 13 2019 10:57pm
Brit Plumber
The brembo marking was very small and in dot markings so difficult to see and I didn’t see it until after I painted them. I still have a spare in the garage (they were V cheap for genuine LR from a dealer). 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #582371 Thu Jun 13 2019 11:30pm
May have been there then in that case but never noticed, but to be fair wasn't actualy looking, the original were pretty rusty so probably wouldn't have seen it anyway.
Post #582372 Thu Jun 13 2019 11:37pm
Buster007
Thanks guys L320 is where I was going wrong! I’m struggling with the finding the larger Brembro calliper 20” Supercharged set I think? Also to upgrade my 4 pot callipers to the larger 6 pot do I need dust covers and different wires? Not knowing a great deal about all this wish there was a garage I could drive in get them to Dom the work and drive out!! Life is never that easy... Big Cry Cheers Laurence.
Post #582375 Fri Jun 14 2019 5:28am
Quick look at a parts list, apart from the obvious discs, calipers, pads and pad fitting kit about the only other thing you need is the wear sensor wire, the backplates appear to be same part number. The large carrier mounting bolts on the original ones can be used to mount the Brembo caliper as they are also appear to be the same number. When I replaced my discs I did use new bolts as they are not very expensive and torqued up pretty tight 275 Nm. if I remember right.
Should be able to get them all from Advance Factors cheap enough.
LR019401 Wear Sensor Wire (1)
SYG500050 Caliper Mounting Bolt (4)
LR016683 Pad Fitting Kit (2)
SYP100241 Disc Retaining Screw (2)
Post #582377 Fri Jun 14 2019 6:21am
Buster007
Thanks Col.... Bow down
Ive been scratching my head for days now trying to find these! Thumbs Up
Just a thought the 2010 equipment will fit my 2012 L320 model?? Cheers Laurence.
Post #582378 Fri Jun 14 2019 6:44am
Some of the part numbers may have been superseded by now, but all the same on the 2010-2013 Sport.
Post #582379 Fri Jun 14 2019 6:58am
Brit Plumber
I had to take my rear discs off to lube the EPB so I got some photos of the Brembo marked disc along with the LR part details.
 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #583967 Sun Jul 14 2019 9:48am
Strange as the S/C never had Brembo brakes on the rear from the factory.
Post #583969 Sun Jul 14 2019 10:01am
Stevepd
Could they be for a 322, in the 1st photo you can see LAND ROVER AH322. I have no knowledge just an observation Thumbs Up
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #583971 Sun Jul 14 2019 10:42am
Brit Plumber
There’s a good chance they share the same brakes. I should do a EPC check on the engineering number and see if they are common to both models.
Did the FFRR have TRW rear callipers? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #583972 Sun Jul 14 2019 10:47am
