Home > Technical > ENGINE OIL GURUS...
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
ENGINE OIL GURUS...
To cut a long (boring) story short I have 2x4 litres of unopened Shell Helix HX8 5W40 engine oil - ACEA A3/B3 A3/B4.
I'd appreciate your thoughts on whether or not this is OK for my 2005 L320 2.7 TDV6. (No DPF).
I would never deviate too far from the recommended oil for obvious reasons and having read various internet articles it looks 'safe'. However the gurus on here have never let me down and I value your experience and opinions. Bow down
Thanks. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #581932 Thu Jun 06 2019 4:14pm
Red Arrow
Needs to be a 5w30 A5 - B5 Ford 913 D spec Thumbs Up
Post #581936 Thu Jun 06 2019 7:30pm
One number represents the thickness at cold and the other number thickness at hot.
So they are quite similar.
I wouldn't like to tell you to use it, but I'd be tempted to use it for 6 months or so.
Obviously if the engine sounds worse, then change it out.
Note these engine aren't the most robust.
Citroen (with this same engine), actually recommend 5W40 ACEA: B3 or B4 during the winter season. So you could use it through winter
Post #581940 Thu Jun 06 2019 8:01pm
IRBails
Australia
I would have no issue to use the 40 especially in warmer conditions. The bottom number is the important one as this is the start viscosity. We are often advised in Australia's warmer conditions to use a slightly higher viscosity rating. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #581954 Fri Jun 07 2019 12:50am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I would never put anything other than the manufacturer specified oil in any car engine. The specification is there for a reason and they know what they are talking about. Anything else is a bad idea and/or a false economy.
Post #581957 Fri Jun 07 2019 8:09am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
The workshop manual is quite clear. 5W30 913C or D spec only RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #581960 Fri Jun 07 2019 9:23am
drdelrrs
Oil flow is an intrinsic part of modern engine cooling.
Various holes around the block and in components are of a very particular size to achieve specific flow rates and pressures. I'd stick to JLR's spec. for the country- especially if there is a JLR or 3rd party warranty on the car
Post #582025 Sat Jun 08 2019 3:36pm
BJH1959
Thank you all for taking the time to reply and for sharing your thoughts. I'll keep to the recommended spec. Barrie.
Post #582064 Sun Jun 09 2019 8:04am
