Home > Technical > 2011 3.0 smoking
Weinel
United Kingdom 2011 Range Rover Sport 3.0 TDV6 SE Sumatra Black
2011 3.0 smoking
Has anyone had this happen or have any ideal what it could be? I had restricted performance come up on the dashboard pulled over & turned her off started her back up & it had gone so guessed she was throwing a hissy fit. The following day I drove about 6 miles went down 2 bypasses so around 50 mph good as gold parked up went into the shop started her up good as gold again 2 mins later I had a little bit of smoke coming out the back had no where to pull over got less than a mile up the road sitting at traffic lights & im smoking the entire road out no warnings on the dash nothing slowly & carefully drove her home cleared to nxt to nothing turned her off left a couple of hours & started her up again & no problems at all used her for short journeys & seems to be good as gold has anyone had anything like this before?
Post #581717 Sat Jun 01 2019 9:49am
Google LTB00487v6 and have a read, might help.
Post #581718 Sat Jun 01 2019 9:55am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
DPF active regen RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #581719 Sat Jun 01 2019 10:04am
knwatkins
Col, the secondary turbo oil drain issue would only be present when the secondary turbo spools up wouldn't it? Ie. At 2800 rpm and above. The OP reports the car smoking when at lights, ie. At idle. Kev
Post #581734 Sat Jun 01 2019 3:22pm
Weinel
Hi thanks for the responses, my vin no is what that bulletin covers just my luck more things to go wrong 😞 took her out on motorway this morning & was good as gold no issues & no smoke at all. Could it just of been a dpf re gen hopefully?
Post #581739 Sat Jun 01 2019 4:21pm
knwatkins
I think you're right. If you hit 2800rpm and you don't get smoke, it isn't a problem with your secondary turbo not draining oil effectively. Kev
Post #581743 Sat Jun 01 2019 7:06pm
Weinel
Hi sorry, do you think my secondary turbo is not draining aswell then? Sorry for coming across dim is this something I need to get looked at? Many thanks
Post #581745 Sat Jun 01 2019 7:44pm
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Had the same prob on MY12 and following the mod it seemed too pull better and no smoke issues.
Piece of mind now it has been done by independent dealer.
Post #581746 Sat Jun 01 2019 7:51pm
Weinel
If you don’t mind me asking how much did the mod cost to have done? Mine doesn’t smoke normally was just that issue a couple of days ago?
Many thanks
Post #581748 Sat Jun 01 2019 8:05pm
RJM16
Sit down take a breathe around the £650 mark
If I remember correctly they also change some rear belts/pulleys at the same time and the water pump.
Post #581749 Sat Jun 01 2019 8:07pm
knwatkins
Personally, no, I don't think that is the case.
LTB00487v6 which Col suggested you to take a look at concerns the secondary turbo oil drain problem. The secondary turbo spools up around 2800rpm. As you stated smoke is emitted when you were at the lights ie. at idle, my personal opinion is that this is not the issue you are experiencing. If you said the smoke was emitted when you were booting it ie. above 2800rpm when the turbo is spinning and forcing air into the engine, I would agree.
By the way, the mod for the secondary turbo oil drain issue is to fit a shorter pipe which allows the oil to drain more effectively away from the turbo into the block instead of into the sump. Kev
Post #581750 Sat Jun 01 2019 8:13pm
knwatkins
If you wanted to do it anyway, you could do it yourself and save some money...
Bits needed:
LR044556 Drain pipe Quantity: 1
LR044555 Blanking plug and gasket kit Quantity: 1
LR013235 Gasket Quantity: 1
Guide:
https://www.disco4.com/forum/d4-secondary-...32471.html Kev
Post #581751 Sat Jun 01 2019 8:21pm
Weinel
Hi i did look at a you tube video to see what was involved. The bulletin did have them part no’s on it aswell. I need to book her in to do the front & rear belts but I might see how much they want to do it at the same time if too much looks like I’ll be getting dirty 😞
Post #581752 Sat Jun 01 2019 8:25pm
Not saying the fault is the drain tube, it was only a suggestion to investigate the possibility. The other thing is what colour is the smoke? oil would be blue, fuel probably black etc.
Post #581757 Sat Jun 01 2019 10:34pm
ilard
Drop two or more 16oz cans of Sea Foam fuel stabiliser (£23 for two off eBay) into the fuel tank and go for a blast. Blows out the cobwebs. Mine was running just fine but I did this anyway for a giggle and it’s now running silky smooth, it’s delightful. But apparently in the US folks use this as a first step in triaging engine niggles.
My next experiment will be with a bottle of Archoil AR6400-D MAX Professional Diesel Engine, Turbo, DPF & CAT Cleaner Concentrate 400ml with a full refuel on top, then a blast down to St Tropez.
I’ll pair this with adding a few mls of this on fuel full ups: - Archoil AR6900-D Max Advanced Diesel Fuel Synthesis - 1 Litre
I ordered this Archoil stuff from powerenhancer.co.uk and got a discount with code AUDICLUB (I’m not aware of any site sponsors selling this stuff) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #581760 Sun Jun 02 2019 6:55am
