Home > General > Suspension Fault - suspension will lift when system is coole |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
yeah the compressor is under the rear left door.
Mon May 27 2019 3:33pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Take it a good Land Rover specialist. We can recommend one if we know your rough location Visitor from fullfatrr.com
Mon May 27 2019 5:05pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Put the car into off road mode and remove the fuses for the air suspension in the engine compartment fuse box. Measure the distance between the centre of the wheel and the bottom of the arch on all four wheels. Leave overnight and re-measure in the morning. If one or more corners have dropped, you have a leak in those respective corners either on the air springs themselves or on the front or rear valve blocks.
Mon May 27 2019 5:40pm |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
cheers. Near Gatwick (West Sussex) |
I believe its still the original compressor. 113k milles now, so its a prime suspect I guess. Will try that test, thanks |
Mon May 27 2019 5:42pm |
Yes, I agree. However, you need to make sure you haven't got any leaks because if you have and you fit a new compressor, it'll be working overtime and you may end up with it failing prematurely. Kev
Mon May 27 2019 5:46pm |
gotcha guys. I'll try the leak test first and see how I get on |
Mon May 27 2019 5:50pm |
