![]() | Home > Technical > suspension won't stay locked in access mode |
Does this happen every time and at all locations ? My drive has a steep slope so depending on how I locate the car on it, sometimes it will spook it into thinking it is grounded or in danger of grounding and it will lift the car. I am assuming there will be sensors linked to the system so if yours does this all the time and anywhere or on any surface, you may want to ask your local indy to give your system a one off healthcheck and to look for any associated fault codes stored by your car to narrow down the cause. |
I also find it can be funny if it’s in park with the park brake on. If I remember, I select access when just finishing my journey or else I put in neutral with the park brake off and let it roll back a little to help the suspension settle. Works 95% of the time when I get the extended mode message after access mode selection. Sometimes it just doesn’t like it!! 2019 5.0 SC SVA (Current)
holland389 Member Since: 21 May 2019 Location: Mayenne Posts: 15 ![]() ![]() |
as far as I can tell, up to now, yes, it happens all the time. I have some other advice i.e. put in neutral with park brake off, perhaps let it settle....etc...! it all seems a bit of a faff really. I only wanted to do it to let my aged relative find it easier to access the car. I have no fault warning lights but I have not checked the fault code message logs......something else I can do. I thought that I'd come onto the forum and some flash of inspiration would be forthcoming but it appears that it might just be idiosyncratic of a 2006 RRSPORT. |
See my response to Father Jack. You all appear to understand that the car has foibles.....! I will do as you describe, mess around a bit, but I don't think its worth wasting time over especially when my parking brake module is making noises and won't apply. Phil |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
Yeah, as plumber says, try and select access in the last 30 seconds of your journey.
I think, as has been suggested, at stand still the sensors think there’s an obstruction so go to extended mode. The suspension geometry massively changes when you select access and all that weight is trying to push the wheels out. It does put a lot of strain on components and can cause excessive and premature ware. 2019 5.0 SC SVA (Current)
Mine to be fair is placed in access every time I park it with no issues (over 50k miles) other than the occasional issue I refer to in my post above. Typical RRS lottery I suppose but see if you can find any fault codes which might help you to a resolution. |
I forgot to reply
