![]() | Home > Maintenance & Modifications > Hissing noise from suspension accumulator |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5135 ![]() ![]() ![]() |
no air addition point.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Good news all round then, Andy! |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Are you sure it is from the accumulator (air tank) because if it was it would be leaking all the time as it has no "on/off" valves as that is done by the central valve block. If you had a leak the air compressor would not be able to achieve the required pressure in the tank and you would get a fault.
Hi Gary,
No hissing.
Sod it - off to the byways of the Lake District I shall go... |
