| RRSPORT.CO.UK | ||
|  | Home > Technical > Rear Load Cover - How to tell the difference ? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Easiest way to tell difference, first picture split tailgate, second picure one piece tailgate.
|  Mon May 13 2019 12:05pm |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | Im pretty sure mine is the 2nd one . Are there any inserts that are meant to be on the car trim pieces to make it fit snug ?
|  Mon May 13 2019 12:07pm |
|  Tue May 14 2019 5:02am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | The length of my cover is 1350mm then the locking lugs stick out about another 10mm each end of cover.
|  Tue May 14 2019 7:11am |
| Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184      | Not sure if these help.
|  Tue May 14 2019 7:18am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | Thank you both for the pics , on the underside of mine (Right) there is a little black tab . Is that meant to sit on/within the cars trim panel or on the outside ? | ||
|  Tue May 14 2019 7:21am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | The black tab is spring loaded and I think somehow lock the cover in place, it does actualy sit in the trim panel so the weight of the cover pushes down on it.
|  Tue May 14 2019 7:33am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | Does this look short to you Col ?
|  Tue May 14 2019 7:36am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Yes it does, have you measured the length of the cover? perhaps the issue is with the trim panel somehow.
|  Tue May 14 2019 7:40am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | At work atm , but will measure when i get something out of my boot and compare with yours . Many thanks ! | ||
|  Tue May 14 2019 7:41am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | It does only just locates in the panel but it has never fell out yet.  | ||||
|  Tue May 14 2019 7:50am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | tried both ways , just doesn't seem to fit snug ! | ||
|  Tue May 14 2019 8:48am |
 Ok had a play , size was the same as stated by you. Managed to shift it a bit to the right and it does seem to fit better now . Its not 100% snug , but judging by your pics looks like it now fits the same as yours   | ||||
|  Tue May 14 2019 10:05am |
|  Tue May 14 2019 10:15am |
| Posting Rules
 Yeah,  couldn't be described as a perfect fit.
