Home > Maintenance & Modifications > Handbrake stuck on
imccarrison
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Handbrake stuck on
Hi all.
Could somebody help. I am wanting to get under the centre console on my 2012 RRS as the EPB is making a screeching noise and stuck on. I was told that I could pull the cable to release it. But I am not sure how to get under the console.
Any help would be appreciated.
Post #580662 Sat May 11 2019 3:37pm
gogsy1956
Not sure on yours being the rotary gear select,,,, the cup holders in the centre console don't come out by any chance ??? 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #580663 Sat May 11 2019 3:49pm
Have a Search in YouTube and see if u can find a vid that matches your interior
Or ur read the owners manual !!!!!
Post #580664 Sat May 11 2019 4:20pm
Tyrefitter
I’m sure it’s under the cup holder behind the gear knob. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #580665 Sat May 11 2019 4:24pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I have the same 2012my with rotary gear selector. On your 2012 if you look in the centre console there are two removeable cup holders. Take them out- can be an effort. Access flap will then be visible. Open. The release mechanism can require a hefty yank mind.
Post #580690 Sun May 12 2019 10:32am
imccarrison
Thanks for all the help.
Discovered that you remove the small plastic bit infront of the actual handbrake lever and they're is two screws. Take these out and you can then remove the actual lever itself. From here I was able to get down and hook onto the cable and release the handbrake.
The red warning light now continues to flash. Do I just put up with this until I repair the EPB or is there away of resetting/turn off.
Thanks again for your help and suggestions.
Ian
Post #580739 Mon May 13 2019 1:47pm
gogsy1956
Won't hurt to put up with it,,, but get it repaired ASAP, I think you were reasonably lucky getting the emergency release to operate,,, not always guaranteed!. Hopefully it can be cleaned up and readjusted. 2010 RRS, TDV8
22" overfinch
Post #580749 Mon May 13 2019 2:59pm
Father Jack
Well you got it done but the easier way is under the cupholder... Maybe best if you pop in your local indy specialist, epb issues are not unusual and they should be able to diagnose quickly.
Post #580780 Tue May 14 2019 7:52am
Brit Plumber
With the 12MY it’s not that easy to get to the release tab through the cup holders, especially if the cable is tight. Best thing to do is get the Screw Driver out of the boot kit, pop the CD slot cover using the flat blade in the bottom and levering up gently (plastic lever is best but the Screw Driver works in an emergency), remove the 2 Philips screws. Then pull the back of the whole console up (it’s on lots of clips) which can take a good tug. The wiring is long enough by design so that you can rotate it up at the back to remove it and then flip it over and rest on the passenger seat. You then have loads of room to get to the cable tab and get the jack handle onto it with out fear of trashing anything.
The SC requires the removal of the gear stick but that again is easy and doesn’t need any tools.
It takes about 2 minutes tops to do it this way. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #580800 Tue May 14 2019 11:31am
imccarrison
Thanks very much for all the help and replies
Ian
Post #580804 Tue May 14 2019 12:02pm
Father Jack
I had no problem via cup holder route. Dismantling the centre console seems a bit extreme.
Post #580809 Tue May 14 2019 12:59pm
Brit Plumber
There wasn’t a hope in hell of getting to mine through the cup holder. I followed directions and videos and found nothing. When I took the console out I could see why, it’s located under the EPB switch. Further digging on the internet revealed many more 2012 owners in the same boat. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #580810 Tue May 14 2019 1:05pm
Father Jack
We clearly have had different experiences but the cupholder route should be tried first and probably works for the majority with no problem at all and they ate understandably not posting about it. It is a lot less involved. Stuck at the side of the road would be no place to take out the console as was my experience. For most if you can't do the cupholder route you need to call recovery or get your indy involved.
Post #580814 Tue May 14 2019 1:27pm
Seem to be a lot of varying opinions how best to do this, but the cup holder is removed on L/H/D vehicles to release it according to L/R workshop manual, but not having had to do it wouldn't really know for sure.
In the center console, a pull ring is installed on the end of the inner cable. The pull ring is designed to fit the hook on
the end of the jack handle which, in combination with a screwdriver shaft, can be used to pull on the cable. The pull
ring can be accessed by removing a circular panel in the bottom of the center console cupholders, on left-hand drive
(LHD) vehicles, or by removing the parking brake switch on right-hand drive (RHD) vehicles.
The pull required to release the latch is approximately 200 N (45 lbf).
Post #580815 Tue May 14 2019 1:38pm
Father Jack
Same on RHD models worked fine for me. Under the cupholder.
Post #580816 Tue May 14 2019 1:43pm
