Home > In Car Electronics > Sat nav update advice
shepp
Hello all
I have the update usb for my 2012 RRS.
Obviously I can drive round for 2.5 hours while it updates, but I have a constant voltage feature on my CTEK charger, designed for performing updates.
If I update without the engine running and the CTEK connected,
I will need the ignition on, but will it time out of the key is not in the car?
Any advice is greatly appreciated
Shepp. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #580354 Mon May 06 2019 5:38pm
shepp
Just turned on the ignition and left the car without the key, it soon turned everything off. don't want this to happen mid update, and not sure if the system will keep itself awake. So I will have to see how long it will stay awake with the key in. MY12 RRS HSE
Gone 90
Gone s2000
Post #580364 Mon May 06 2019 7:11pm
shepp
Just an update,
Tried leaving it with the ignition on, key inside, and the 4x4 screen visible
The dash stayed on, all interior display illumination stayed on, but the ventilation and nav screen went to sleep.
If I ran the update would it still go to sleep?, If so, does anyone know how to prevent it going to sleep. MY12 RRS HSE
Gone 90
Gone s2000
Post #580374 Mon May 06 2019 8:33pm
scarey
leave the usb stick in and drive normally...if you stop ,the update will pause until you get going again ....
Post #580380 Mon May 06 2019 9:43pm
shepp
I'm not sure it does, there are warnings not to turn off the ignition. Apparently it stuffs the satnav and phone.
There must be a way of updating without the engine running for 2.5 hours MY12 RRS HSE
Gone 90
Gone s2000
Post #580381 Mon May 06 2019 9:48pm
Brit Plumber
The entertainment system is designed to Shutt off after xx minutes (can’t remember the exact length of time). It is also designed to enter low power mode when the engine is not running. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580390 Mon May 06 2019 11:30pm
Post #580391 Mon May 06 2019 11:33pm
shepp
Cheers lads
Sets my mind at ease a bit, as quite a few stories of the sat nav completely conking after update. MY12 RRS HSE
Gone 90
Gone s2000
Post #580416 Tue May 07 2019 9:13am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
You are lucky having a USB stick driven system.
What about 2010/2011 cars with a hardisk? You need JLR diagnostic equipment for a navigation upgrade.
JLR said that they need to let the engine run idle for 5 hours ! That seems rediculeous, particularly with an eye to the DPF .
Does somebody (Col?) has a suggestion i.c. a better plan? RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #580428 Tue May 07 2019 12:26pm
scarey
there isnt one...
and you'll only get no newer than 2014 maps..
Post #580487 Wed May 08 2019 9:26am
Smarttech
Where did you buy the update from and how much was it as thinking about doing my 2012 sport.
Also how up to date are the maps 2019 ? 2019 4.4 SDV8 Autobiography Velocity blue.
2017 SVR. SVO Scafell grey Ebony interior. Gone
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #580515 Wed May 08 2019 2:56pm
shepp
Pm sent, they are classed as 2018/2019 MY12 RRS HSE
Gone 90
Gone s2000
Post #580528 Wed May 08 2019 7:37pm
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Got my USB from the HERE website and after it being replaced because it froze, the car is without sat nav, and telephone.
Looks like a new unit as HERE will not cough up, even thought the map was attempted by Land Rover Dealers as well under instructions from the USB provider at my expense for 4 days.
Post #580648 Sat May 11 2019 7:29am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Last September I was advised the newest maps get released in May, although not usually sold via Landrover until September October time. So might be worth holding on a couple of weeks if you can, to get the 2019/20 map. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #580658 Sat May 11 2019 11:14am
shepp
After 2hours 50minutes the update finally completed. I kept it running for the full duration to ensure there were no errors.
Hopefully my maps should represent the roads I drive on. MY12 RRS HSE
Gone 90
Gone s2000
Post #580711 Sun May 12 2019 10:38pm
