Home > General > Active Dampers?
knwatkins
Active Dampers?
Hi all, without taking the struts off my car, how would I know if I have the active dampers or not?
According to Topix, I have the active roll control which I assume is the ACE hydraulic ARBs, but I'm not sure if my struts are the electronically controlled variants or not. Kev
Post #580175 Fri May 03 2019 9:53am
Brit Plumber
Is this not part of the dynamic setup using the rotary knob upto 2012 and switchpack 12 on? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580178 Fri May 03 2019 10:50am
Disco_Mikey
Adaptive Dynamic struts have 2 small wires coming out the middle of the strut, right at the top Thumbs Up
Post #580185 Fri May 03 2019 3:25pm
Tim in Scotland
Is it not easier to look for the hydraulic oil top up cap near the radiator? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #580186 Fri May 03 2019 3:45pm
Disco_Mikey
Different system Tim Thumbs Up
Post #580187 Fri May 03 2019 4:30pm
If you've got the dynamic programme on Terrain Response (the double-S to the left of the normal setting on the dial/switch) then you have adaptive dampers. 2012 SDV6 - it's missing a couple of cylinders
Post #580188 Fri May 03 2019 4:39pm
knwatkins
That's great, thanks guys. I've just nipped out to the car and I can confirm that there is no 'SS' to the left of the normal setting on the terrain response ie. I have standard dampers.
Tim, as Mike says, it's a different system, the hydraulic fluid is for the active ARBs. The active dampers are for electronic control of the damping rate of the suspension ie. firmness/softeness. Kev
Post #580190 Fri May 03 2019 6:07pm
Tim in Scotland
Embarassed Sorry i’m Getting out of touch after almost a year of not owning one...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #580200 Fri May 03 2019 8:42pm
knwatkins
I probably didn't help the case by saying that I have active roll control in my original post. I just wasn't sure that if I had ARC, this may have meant that I automatically had the active dampers. Now I know that this is definitely not the case Smile Kev
Post #580201 Fri May 03 2019 8:50pm
It would be worth checking the top of a damper too, just to be absolutely sure, if you're planning on buying replacements. Any wires going means you do have active dampers fitted. No wires (just the air pipe) means you don't. 2012 SDV6 - it's missing a couple of cylinders
Post #580236 Sat May 04 2019 11:07am
knwatkins
Thanks guys, I just checked the top of them and there is only the airline there and no wiring Thumbs Up Kev
Post #580552 Thu May 09 2019 11:27am
