![]() | Home > General > Range Rover sport poor acceleration |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
May be worth adding.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5052 ![]() ![]() ![]() |
you can certainly blank them as a test to see if it is EGR related.
Chromer2828 Member Since: 29 Apr 2019 Location: Devon Posts: 8 ![]() ![]() ![]() |
Thanks for the replies, I will get some of that Wynn’s and chuck it in nothing to lose. The actuator on my turbo is moving ok as far as I can see. |
Turbo? Or Turbos? The TDV8 has 2 so if the turbo rod is moving fine on yours you may want to check the other one if you haven't. 2019 5.0 SC SVA (Current)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9066 ![]() ![]() ![]() |
He's got an early TDV6 so single turbo. 2012 SDV6 - it's missing a couple of cylinders
Lol, sorry misread it as TDV8, 2019 5.0 SC SVA (Current)
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
Sticky turbo actuator rod will cause that. You can get at it from top or bottom. From top its battery and battery tray out; from underneath you can take the heatshield off to see it. You should be able to move it back and forth with ease (about an inch travel). If not, it is seized and wants lubricating and working back and forth until free. |
Thanks for the reply, the actuator rod is what controls the wastegate. Is it easier to get at with the battery out than through the wheel arch thanks in advance |
No
Even though I can hear it, is it still possible it’s not moving |
The egrs also make a noise at similar times. |
Actually if the rod is stuck, it is normally accompanied by the message ‘Engine System Fault’ on the dash, that keeps flashing up every 20 seconds or so. If you can hear it and you don’t have that fault on the dash, chances are it isn’t that. Induction leak somewhere. And it is easier to get at through the wheel arch |
All doom and gloom for my range, I took it out this morning and she started smoking. Then the cab started to fill with smoke. I pulled over and the manifold on the right hand side had holes blown in it and it was smoking out of them. Called recovery and the guy said he’d seen it quite often. He told me the egr on that side was faulty and it causes intense heat. The car starts and ticks over fine so hopefully not too much damage. Started taking of the intake manifold which is a nightmare job so far. Intend to replace it along with both egr valves and pray the car will be ok. 2 weeks of ownership, not the best start |
Do you have any kind of warranty where you bought it from? Kev
