Home > General > Swapping interior from facelift into pre-facelift
Tom_w_27
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all, I've been offered a nice set of facelift seats and doors cards. Will these fit and all electrics work, when fitted to Pre-facelift model?
Post #579402 Mon Apr 22 2019 9:29am
Silverman
United Kingdom 2006 Range Rover Sport 4.4 V8 HST Java Black
I’d like to know this also. I’ve seen it done but I’d like to know if it’s a simple swap with no mods
Thanks
Post #579612 Thu Apr 25 2019 4:39pm
Red Arrow
You need to use the pre facelift bases - split the backs and bases off and swap over with a bit of faffiing about on the wiring side of things but its relatively straight forward Thumbs Up
Post #579627 Thu Apr 25 2019 8:08pm
Silverman
Red arrow - So when you say bases is that the entire base of the front seats including the cushion? So in effect you also have to swap seat covers on the base?
Or are you saying theres a metal base that just contains the runners and electrics that you can split from the cushion section and swap over to the facelift seat?
How long did it take you to do?
Thanks mate
Post #579646 Thu Apr 25 2019 10:48pm
Red Arrow
yes split the metal runners with the electrics and take pics of the wiring as the newer wiring has some different wires .
so with the old seat take the seat base off - from memory 4 torx bolts and then do the same with the back and then transfer then do the same with the new seats and transfer the newer style base and back onto the old frame that has the old switch gear etc .
i fitted a 2012 autobiography trim into my 2007 model .
seats took around an hour each including the wiring and sorting the heated seat pad wiring out but its not a hard job.
it was a couple of years ago now so i dont have any pics
Post #579683 Fri Apr 26 2019 5:09pm
Tom_w_27
Nice one Red Arrow appreciate the reply. Thumbs Up
Post #579685 Fri Apr 26 2019 5:27pm
Silverman
Thanks mate.. This is great info. Doesn’t sound too big of a job Smile
Post #579688 Fri Apr 26 2019 5:36pm
