Home > General > Another suspension issue
sid1968
United Kingdom 2005 Range Rover Sport TDV6 Autobiography Java Black
Going back to my previous post ie fitted rear level sensor got it calibrated no fault codes. Took it from the garage now if I drive over 50mph red suspension fault comes on and do not exceed 30mph message until I stop restart engine then same again if i go over 50ish mph. Also noticed a tilt of the vehicle from the rear.
Please see below of the screenshot of the 4x4 screen. Front wheels are fine but rear right is different height to the left.
Booked it back to the garage. But any ideas from pros
Thanx
Post #579606 Thu Apr 25 2019 3:00pm
It appears to be low in the 4x4 screen even though it says "standard" at the top. When the error comes up, does the vehicle drop the suspension down? If so, that suggests a calibration issue. Dropping to the bump stops occurs if the system thinks it's cross-axled. It would also throw up a red dash light. 2012 SDV6 - it's missing a couple of cylinders
Post #579611 Thu Apr 25 2019 4:28pm
sid1968
Don't really no. Because when the red error light comes on it becomes very bouncy unbearable
Post #579613 Thu Apr 25 2019 5:03pm
I would take it back and get it re calibrated.
Looks high
Post #579614 Thu Apr 25 2019 5:36pm
sid1968
I have taken the car back to the garage
The mechanic cannot adjust the back suspension. It's sitting lower than the front.
Does anyone one any good range rover specialist around Blackburn area?
Post #579666 Fri Apr 26 2019 12:04pm
