Home > General > Side Step Metal Discolouration
Page 3 of 3 <123
mrluke
I quite like the look of these
https://www.sidesteps.co.uk/shop/range-rov...ide-steps/
Mines a 2012/2013 and the dirt looks really ground in ! they could just need a *proper* scrub, but the black ones would look nice Very Happy
Post #578391 Thu Apr 04 2019 8:16am
Autobiography1969
£180 just for the edging seems a lot..
How can you tell if the ones on the car
are supplied by JLR, or will they fit after market
ones as well? ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #578395 Thu Apr 04 2019 8:34am
mrluke
Check Topix maybe ? should be listed as a build option on the car .
at the bottom is states
Please note that if you require a replacement strip for a QuickTread product (as opposed to Land Rover OEM) these are listed separately and are available for Range Rover Sport, Discovery 3, Discovery 4 and Freelander 2.
Post #578397 Thu Apr 04 2019 8:36am
Probably not listed on topix if a dealer fitted option.
Post #578398 Thu Apr 04 2019 8:50am
Eaters
With any of the options, how can you be sure that they wont just deteriorate like the OPs have? Are OEM LR ones resistant to discolouration? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #578399 Thu Apr 04 2019 8:56am
Signori
Had mine sprayed satin black today by a mate who owns a body shop, really happy with how they came out
Before
After
Post #578459 Fri Apr 05 2019 2:45pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Looks Good Thumbs Up
I think that this is the best option to resolve the aluminium 'staining' problem long term.
Couple of questions:
1. Did he remove the aluminium trims or spray them while still on the side steps? I am not sure if the trims can be removed and re-fixed?
2. Did he use an etch primer on the aluminium trim before painting?
Thanks.
Post #578461 Fri Apr 05 2019 3:25pm
Autobiography1969
Before
After
Looks very smart,
Think they need to be colour coded like yours to get the best look,,
Indus Silver for me.. ===========================================
Post #578467 Fri Apr 05 2019 5:49pm
Signori
Thanks.
He didn't remove them, just masked them off to spray. Not sure what he used on them tbh
Post #578491 Sat Apr 06 2019 7:33am
grimreaper
Noticed mine had gone all streaky as well with them being solid aluminium I used 600 grit wet and dry then 1000 wet n dry then when dry I waxed them look awesome not sure how long they will last looking good but only a half hour job to do both sides
Mark.
Post #615710 Tue Jul 13 2021 1:19pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Started replacing my side steps today. Used a disc cutter and just cut through the brackets to get them off it was only the alloy trim and plastic holding the passenger side together.
Cleaned up the sills and washed all the mud out of the arches, sills were in really good nick this being the worst area.
Cleaned up and treated with Kurust. Took the opportunity to clean up the air tank as well
I’ll treat all areas with Lanoguard and fit the new ones tomorrow. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #616143 Sun Jul 25 2021 9:11pm
Page 3 of 3 <123
