![]() | Home > Technical > Failed prop shaft |
I wonder if the clutch centre would have admitted the real cause of the problem after dropping the box |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
No, more likely the propshaft was damaged when the box was dropped out.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5120 ![]() ![]() ![]() |
so yours saying the they dropped the gearbox and transfer box out as one unit ? |
I've no idea what they other garage did when they changed the clutch. I know if we do a clutch, we drop the lot as one. If we're removing an automatic, then we take the transfer box off first.
Got a feeling Kev was referring to the Clutch Centre that did the job. Cheers Col |
My bad! Yes, Kev was indeed referring to the Clutch Centre, not the centre plate... duh....
No problem Joe. I must admit I was a little confused with the reply |
