Home > General > spare wheel issue
keith277
spare wheel issue
I have a RRS 2017 model that came with the space saver spare wheel.. I have purchased a full size 21 inch wheel as I do long distances and want a "proper" spare, however when I've tried to put it in the spare wheel housing in the boot it doesn't sit flush... is there something I can do to make it sit flush
thanks Keith
Post #578200 Sun Mar 31 2019 7:26pm
Tyrefitter
A 21" should fit as I have a 22" in mine,,is their something under the space saver that's stopping if fitting to the bottom of the well.? Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #578211 Mon Apr 01 2019 7:55am
keith277
Hi thanks for the reply, and yes there’s a small dome shaped insert there but I cannot see how it removes, I’ll maybe have to ask my local RR garage
Regards
Keith
Post #578212 Mon Apr 01 2019 7:57am
Tyrefitter
The small dome thing is the compressor for the air suspension,,the spare sits over it. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #578213 Mon Apr 01 2019 7:59am
keith277
Ok thanks in that case I can’t see anything that’s obstructing it, the 21 inch extends out around 2 inches above the well in the boot.. I’ll take a couple of pics shortly and add them to this thread
Thanks
Keith
Post #578214 Mon Apr 01 2019 8:17am
Tyrefitter
This is a pic of mine
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #578216 Mon Apr 01 2019 9:01am
Brit Plumber
I think you need to post up some comparison measurements like wheel width of new wheel, width of space saver, depth of well for spare etc. Did the spacesaver sit flush with the floor? If it did then I’d say it was a space saver for that reason. In other cars if you have a full size wheel, there are packing pieces to raise the level of the floor to match that of the wheel. That obviously won’t work on a vehicle like the RRS but that’s how other manufacturers do it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #578217 Mon Apr 01 2019 9:12am
keith277
Thanks Andy.. just realiesd that I had not removed the polystyrene liner Embarassed
Thanks for the help.
Regards
Keith
Post #578219 Mon Apr 01 2019 9:26am
I think you may find there are two different liners listed one for space saver spare and one for full size spare as they act as a insulator.
LR033233 Space Saver
LR033234 Full Size Spare
Post #578220 Mon Apr 01 2019 9:35am
Tyrefitter
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter That's your problem then. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #578221 Mon Apr 01 2019 9:59am
