Home > Maintenance & Modifications > Anyone for a 6" lift kit?
Twisted Evil
http://jaustonfab.com/range-rover-lift-kits/
Quote:
Our patented 6″ lift kit increases approach, departure, high center and decreased body drag. The standard kit utilizes the air ride system, keeping all of the travel modes of the range rover design & characteristics (entry, normal ride & off-road) at the touch of a button. The kits design keeps all of the Range Rovers suspension engineers design working angles. This a bolt on kit.
Post #568578 Fri Nov 09 2018 8:56am
Tim in Scotland
There are a couple of parts missing that are essential for such a big lift - portable steps so driver and passenger can get in an out when the body rests on those huge tyres......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #568593 Fri Nov 09 2018 10:53am
I see Johnson also makes rods for the L405 and L494 now: http://johnsonrods.com/johnson_rods_3_003.htm
a bit more modest lift at 1.5 inches
now sure how they differ from the original rods, they don't provide any explanations on their website. --
Post #578152 Sat Mar 30 2019 3:24pm
a reply from Greg Johnson regarding the lift rods:
Quote:
The lift works with the air suspension to give you a 1.5 inch lift above the stock position.
The installation is very simple. Remove one wheel at a time and exchange the stock part for the Johnson Rod.
The entire process should take less than one hour and does not require any special tools.
The drive train is not a problem as the Range Rover was built to operate with a lifting air suspension.
Post #578178 Sat Mar 30 2019 9:41pm
