Home > General > Tailglass stuck after using Tailgate
flindersstation
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Hi folks
Tailglass wasn't working so I got myself a new switch and now it's working. But, when I now open and close the tailgate the tailglass will not work. If I take the trim off and click the latch then it works again but there must be a better way to fix this.
I've only been using tailglass for weeks now and I prefer that but I needed to use tailgate yesterday and now I can't use tailglass without taking trim off again and manually clicking the latch. Any ideas? Quite a lot of posts about tailglass but mostly about switches, which helped me a lot so far.
Cheers guys
Kevin,. 2007 RRS 2.7 HSE (Current)
2015 Audi A1 1.4TSI (Current)
2015 Audi A6 2.0 TDI (Gone)
1994 Pajero 2.8 TD (Gone)
Post #577676 Sat Mar 23 2019 8:27am
Brit Plumber
Put your old switch back on again and see if the problem goes away (but it will bring back your original fault) that way you will no if it’s your new switch or a new issue. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577679 Sat Mar 23 2019 9:49am
Pufftmw
There's a sensor or pressure switch or something that stops you opening the glass when the tailgate is open. Work out how that operates and check that out just in case its thinking the tailgate is constantly open.
Post #577686 Sat Mar 23 2019 1:34pm
if you press the lock and unlock buttons on the dash together for 5 seconds that open the main tail gate.
Might save you taking the trim off
if the glass is open you should get a warning on the dash.
you could also program the LR fob button to do the tailgate.
That might prove if its the button or wiring etc
Post #577693 Sat Mar 23 2019 3:09pm
flindersstation
Thanks for the suggestions guys. My brother was replacing an EGR valve today ( well fiddly but a successs) and we had the battery off. Tailglass now working. Open tailgate and now tailglass not working. Disconnect battery and reconnect and working again.....so pointing to a sensor on the tailgate, I will investigate 2007 RRS 2.7 HSE (Current)
Post #577741 Sun Mar 24 2019 6:04pm
You do realise the software stops you opening them at the same time.
Post #577742 Sun Mar 24 2019 6:26pm
flindersstation
Yes sorry I wasn’t clear, I meant open and close tailgate and then tailglass will not work.... 2007 RRS 2.7 HSE (Current)
Post #577744 Sun Mar 24 2019 6:30pm
