![]() | Home > Technical > Turbo Actuator - can this be bought separately? |
Redynet Member Since: 23 Mar 2019 Location: Corralejo Posts: 3 ![]() ![]() |
I have a faulty actuator on a working turbo - can an actuator be sourced separately (TDV8 - right hand side actuator needed) |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5070 ![]() ![]() ![]() |
Do you mean this? LR023087 R/H
Hi Its the actuator itself (i.e. the electronic motor) rather than the rod assembly, but thanks |
Item 5 doesn't appear to be avaliable separately from L/R, unless you could get one from a aftermarket supplier.
Duplicate Reply.
Thanks for the comments - i have found a company in the UK who has reconditioned actuators available - fingers crossed! |
arwV8 Member Since: 17 Feb 2018 Location: Worcestershire Posts: 18 ![]() ![]() ![]() |
Just had my turbo replaced by JLR under extended warranty. Issue wasn't the turbo but the actuator electronics box - Oil had migrated down the wire in the harness from the oil level sensor that happens to go to turboA actuator module.
