Home > Maintenance & Modifications > Dynamic Fluid
Kems
Dynamic Fluid
Good evening
I’m after a bit of advice. The Dynamic fluid is low on my RRS so I need to up. I checked the handbook and it doesn’t reference any specification for the required PAS fluid other that Texaco Cold Climate. I have some Power Steering fluid in the garage which is green (I think that is cold climate?). Am I ok to use it or should I get the Texaco stuff or LR?
Thanks for any help.
Mark
Post #577589 Thu Mar 21 2019 9:05pm
Tyrefitter
Probably better off pm’ing Disco mikey,,he will know Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #577590 Thu Mar 21 2019 9:27pm
http://www.rrsport.co.uk/forum/topic53552.html
Post #577591 Thu Mar 21 2019 9:28pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Buy the power steering fluid from the dealership. It is the same stuff.
Post #577595 Thu Mar 21 2019 10:06pm
Kems
Thanks all
Post #577613 Fri Mar 22 2019 9:41am
Brit Plumber
If it’s low, how low and where’s it gone? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577662 Fri Mar 22 2019 8:55pm
CANROVER
Usually it leaks via the rear sway bar.... A pricey fix but you can delay the leak and buy yourself some time to save up by buying Power steering fluid stop leak. Lucas Works quite well but don't think you can get away with it being a permanent fix. Sooner or later that sway bar will have to be replaced.
Post #577666 Sat Mar 23 2019 1:07am
I don’t think u should put stop leak into the ace system.
Post #577671 Sat Mar 23 2019 8:39am
CANROVER
It's been done by a few people on this forum.... When I did it and had the dealership replace the sway bar nothing happened. Just don't think of it as a long term or permanent solution, that's all. Rear De-articulating sway bars aren't cheap.
Post #577677 Sat Mar 23 2019 9:43am
