Home > Maintenance & Modifications > JLR dignostics.... compare to IID
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Has anyone access to or knowledge of such?
benefit compared to IID Tool if any?
its 2nd hand hardware but up to date software.... similar cost to buy as the IID tool.
any experiences of, would be interested to hear about.
The Software JLR V158 covers the following;
Jaguar 1996 to 2018
Land Rover 2005 to 2018
RANGE ROVER 2005 TO 2018
Which Includes the following models;
JAGUAR LINES LAND ROVER LINES
X100 L316
X150 L319
X202 L320
X250 L322
X350 L359
X351 L538
X400
http://www.rrsport.co.uk/gallery/albums/us...%20s.w.PNG 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #577061 Fri Mar 15 2019 12:18pm
Disco_Mikey
Programming subscriptions are required for any form of programming
CCF editing is very limited
SDD is a absolute ball ache to use + navigate
Aftermarket/cloned VCM's are prone to issues, which could result in an expensive garden ornament
An internet connection is required to us SDD (I think Confused )
Post #577063 Fri Mar 15 2019 12:50pm
Disco_Mikey
And it won't cover up to 2018MY, will only do upto 16MY, as anything afterwards reqs Pathfinder
Post #577064 Fri Mar 15 2019 12:51pm
mrluke
Going to be cracked with a 2109 expiry date for Full offline use Wink
Post #577075 Fri Mar 15 2019 3:09pm
geoffsnook
I has SSD and found it a right pain then bought an IDD so much easier and safer to use.You will not end up with a 2.5 tonne paper weight as you may with SDD
Post #577077 Fri Mar 15 2019 3:12pm
Brit Plumber
I have both, IID is very handy. SDD is good for everything else. I paid £50 for SDD with a log in but today it hasn’t worked, the log in screen has changed in the last update. I’ve emailed the seller for an updated password. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #577107 Fri Mar 15 2019 8:04pm
Brit Plumber
Seller true to his word has sorted it all out and SDD is working again. 2019 5.0 SC SVA (Current)
Post #577150 Sat Mar 16 2019 11:14am
