![]() | Home > Maintenance & Modifications > Standard Height values |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
462mm measured vertically from centre of half shaft (wheel) to edge of the wheelarch. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
That's different to the workshop manual Col. Which is not surprising when one considers this is Land Rover we're talking about. |
Not sure where I got that document from Wayne, thought I downloaded it off Topix, same dimension as Gap list in their manual, but you are right with L/R they do complicate and contradict themselves quite a bit. |
Superb, thanks gents |
http://www.disco4.com/wiki/IIDTool_Calibration_Values In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
All of the figures quoted are within a few mm and definitely within the in-use operating tolerance of the suspension system anyway so which you choose is probably not that important. |
