Home > Maintenance & Modifications > Check your oil there is no low level warning
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Afternoon all
It would appear that there is NO low oil level warning on the RR Sport, a friend of mine has lost his SDV6 engine due to insufficient oil and there was no warning given by the car.
So check your oil level regularly. Thumbs Up
Post #576433 Tue Mar 05 2019 2:28pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
bring back the dip stick i say!
i hate these stupid oil check displays....
wait t heat up the engine... then wait 10 minutes after power off so that the system can measure the settled oil level....
no other way to do it.
Rolling Eyes Rolling Eyes Rolling Eyes 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #576439 Tue Mar 05 2019 5:40pm
riverblanche
check ours before I start the car only takes 30 secs or so
although
swmbo still wants to know why it takes me Soooooooo long to get the car out of the garage, I dont think she ever checks it Whistle
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #576443 Tue Mar 05 2019 6:18pm
MGO
the new sport must allow the level to read without the engine warmed up so...
2012 model needs engine oil up to temp. 2007 TDV6 RRS HSE..now gone
Post #576444 Tue Mar 05 2019 6:20pm
MGO
just checked the operator manual
there is a low level warning if the oil is low
even says how much to add in
your friend must be like my wife.... oblivious to any warnings. Laughing 2007 TDV6 RRS HSE..now gone
Post #576471 Tue Mar 05 2019 9:45pm
garrycol
Australia
Re: Check your oil there is no low level warning
1JBS wrote:
Afternoon all
Surely the low oil pressure light would start to come on as the oil level got down to the level of the pickup. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #576484 Tue Mar 05 2019 11:47pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
The low pressure oil light should be renamed the “fit a new engine light”. There is no oil level low light in the RRS1, which when there is no dipstick, except the one behind the wheel, is IMHO a major design fault.
Post #576525 Wed Mar 06 2019 5:24pm
scrumps
I’ve posted this before.
You don’t think the Dealers wait 10mins to check the oil during a service do you?
Turn on the ignition, without touching the brake pedal, pull the bonnet release, clear the dash alerts and then read the oil level.
If hot or just stopped the engine, allow for the level to be little off as there will have been little “drain back” to the sump.
Close the bonnet before driving off.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #576544 Wed Mar 06 2019 7:48pm
So having the bonnet open allows you to bypass the wait system ?
Post #576558 Wed Mar 06 2019 8:57pm
MGO
i'll try it in the morning.
good stuff if it does. 2007 TDV6 RRS HSE..now gone
Post #576561 Wed Mar 06 2019 9:12pm
Brit Plumber
Doesn’t work on mine, the oil has to be warm and I have to wait 10 mins after engine off or it tells me oil level not available. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #576566 Wed Mar 06 2019 9:32pm
scrumps
IIRC on a 2012 you have to press cancel on the cruise control twice for it to work.
Post #576570 Wed Mar 06 2019 9:53pm
Brit Plumber
I’ll give it a go, I always forget to check after 10 mins so that would be god send. 2019 5.0 SC SVA (Current)
Post #576571 Wed Mar 06 2019 9:58pm
Stevepd
So that’s potentially running on low oil for 10 mins until the system tells your low on oil Shocked .
Being a preface lift owner I’m glad for the dipstick. Could you imagine checking the oil seeing it’s low then consciously starting it without a top up = crazy.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #576594 Thu Mar 07 2019 8:32am
Strange, mine checks o.k. whether checked after stopping for 10 mins. or left overnight and checked in morning when cold, don't have to press any cruise control buttons, open bonnet or anything like that. Of course I am assuming it works o.k. but never put any oil in between services and it hasn't gone bang yet. Laughing Could just lift throttle pedal slightly as if pressed at all when checking it will say not available or whatever it says.
Post #576598 Thu Mar 07 2019 10:15am
