Home > Technical > AFS head light problem
Alz
United Kingdom 2007 Range Rover Sport TDV8 Autobiography Java Black
Just bought car and it’s been upgraded,adaptive head light yellow warning light on ,I removed headlights found only one ballast on bottom of light but my car as cornering lights and adaptive lights called Land Rover and confirmed I do have adaptive lights so I have none AfS lights fitted if I remove the old lights and buy the Ome led style AFS lights with the adaptive lighting will they work or will the adaptive lights reject the lights due to not being proper Land Rover the ones fitted now are working fine apart from the adaptive not working but I would like to remove this earring light of my dash or can the adaptive be turned off completely
Post #576291 Sun Mar 03 2019 7:48pm
Ginge
I have the same issue and just want to know if I can disconnect the warning light on the dash as I don't need afs so I don't care that the upgraded lights don't have it! Hoping I can just unplug something so I don't have to see that flashing light
Post #576781 Sun Mar 10 2019 10:27am
Alz
I have been in phone to the firm the makes the lights and the adaptive lights will not work unless the car is from 2010 you can’t turn the adaptive warning light off as the car is picking up a fault I don’t no why there selling the lights as 2005 /2010 upgrade if they don’t even work correctly as none of the ads say the adaptive lights will not work also I have adaptive lights with cornering light and the cornering lights have burned out useing the h8 35
Watt that’s recommended so only use led bulbs
Post #576785 Sun Mar 10 2019 10:45am
Ginge
There is a you tube video that says using the Gap IID tool you can turn the afs to 'not fitted' and then the warning light doesn't appear
Going to try and get this sorted!!
Post #576792 Sun Mar 10 2019 11:29am
Alz
Yes you can on the older Range Rover but not on the Range Rover sport I have Range Rover diagnostic machine and that video isn’t the Range Rover sport
Post #576808 Sun Mar 10 2019 2:33pm
they are similar electronics though.
Have you tried? you can enable or disable almost anything with an IID !
Post #576816 Sun Mar 10 2019 3:36pm
Brit Plumber
In my experience with LR diagnostics, if the CCF doesn’t show it fitted, it won’t BIT it through the CAN bus and therefore won’t find errors. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #576831 Sun Mar 10 2019 9:01pm
Ginge
My rrs has the autobiography kit fitted s on originaly (I believe) it had afs but with the new lights it doesn't have this so the computer is confused and throwing up this fault so after watching the you tube video I wondered if it would work on mine and turn off afs it's a 2008
Post #576840 Mon Mar 11 2019 7:47am
Brit Plumber
It’s got to be worth a go trying to turn it off. I’m pretty sure it would work.
It’s not the same but I recently turned on rear seat entertainment in the CCF and I lost The Tv signal and had 2 RSE fails for the screens. No surprise as I don’t have RSE! I turned the option off in CCF and Tv has reappeared and after clearing the faults they didn’t come back. It should be the same for AFS, turn it off in the CCF and the car won’t do a BIT for the AFS. 2019 5.0 SC SVA (Current)
Post #576849 Mon Mar 11 2019 12:54pm
Ginge
I have ordered the Gap IID tool and can't wait now to see if I can sort 2 of my problems by using it 🤞🤞
Post #576880 Mon Mar 11 2019 11:21pm
Ginge
Afs update
Just to say the Gap IID tool arrived and I have managed to get the flashing afs light extinguished by following the you tube video!! At least I dint have to put up with that flashing light anymore 😊😊😊
Post #577097 Fri Mar 15 2019 7:35pm
