![]() | Home > Faults & Fixes > RRS TDV8 owner after help |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4501 ![]() ![]() ![]() |
Sounds like turbos... |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 219 ![]() ![]() ![]() |
I would check that petrol has not been fuelled instead of diesel, my wife did that and swore blind she didn't, your symptoms sound similar |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
Is their not an anti fuelling device built into the filler, prevents you from filling with petrol,, tried it once with mine and it closed off the filler immediately, I got about 16p worth of petrol in it.
iforland Member Since: 13 Apr 2015 Location: Redditch Posts: 47 ![]() ![]() |
I'm sure the turbo has gone...the inlet hose is full of oil.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
It can be done but is "a |
Commiserations. My SDV6 did both turbos a year ago. I remember the thread referred to but in my case/maybe for SDV6's the view was body off. So had a service and both the belts done same time. Also, while it might be possible to save a few quid using rebuilt or exchange turbos wouldn't recommend it, better to bite the bullet and fit new.
done some more work today, stripped the passenger wheel and took the lower inter-cooler pipe off...See the video:
Commiserations and good luck! Kev
Ok, today I managed to get the passenger side turbo off the car without removing the body...
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1549 ![]() ![]() ![]() |
Good job. Well done. Looking forward to hearing some more good news shortly. Robin
Today's work cut short by weather, but good news is that the new turbo is now back in!! It's always quicker putting stuff back together.
So I've found out what happened to the old turbo.
Ok, I've been a little worried about what caused this to fail in the first place so I've done some digging and I think I may have found a possible cause.
A great strip down and analysis! Glad you got it sorted |
