![]() | Home > Technical > Drivers Seat memory module question |
| Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31
I had the same clicking noise problem you mentioned. I disconnected all the connectors on the module and let it sit for 30 minutes. Reconnected them back and haven’t had a problem since. You might want to give that a try before buying another module 2006 LR3 HSE
| Ziguk Member Since: 01 Feb 2019 Location: Wrexham Posts: 19
Thanks did try that took module out for a few hours plugged back in now I get nothing at all |
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
Plug it in and see it will either work or not would not have thought it would need coding but i stand to be corrected i thought you only needed to tell the car it has powered seats |
If your power seats are not working after you re plugged the module back in then the module is probably dead. I’d replace it with the same Part # unless LR has a superceded part #. There shouldn’t be any programming needed for a new module. 2006 LR3 HSE
| All times are GMT |
