Home > In Car Electronics > Standard double din stereo? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
BTW, the car connector does not have an ignition supply available, that would usually connect to the red or yellow head unit wire.
Tue Feb 26 2019 8:22pm |
M9G UK Member Since: 02 Feb 2019 Location: Somerset Posts: 160 |
Thanks for that, will do
Tue Feb 26 2019 8:32pm |
Ok so I had a response from InCarTec today with a list of components I will need and yes they have the ability to keep the satnav/4x4 screen still working but it means the original stereo has to still be installed but somewhere in behind the dash but will still loose audio from the satnav but can buy another really expensive cable to get the satnav audio to work. all in its going to be well over £200 just for the cables and to be honest im not keen on fitting the original stereo in behind the dash and I don't consider the satnav much good anyway.
Wed Feb 27 2019 8:06pm |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
http://www.rrsport.co.uk/gallery/picEditor.php
Wed Feb 27 2019 8:21pm |
As you say the standard nav is hopeless.
Wed Feb 27 2019 8:54pm |
nothing there mani just a pic editor 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Wed Feb 27 2019 8:55pm |
2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys Xtrons Android head unit |
Wed Feb 27 2019 8:56pm |
Harness arrived today and so I quickly plugged it all in to see what happens and we had Little Mix blasting out
Thu Feb 28 2019 7:14pm |
I think you probably need to unplug the connectors on the display above, (well the main connector with all the wires)
Thu Feb 28 2019 7:27pm |
Ok but thinking about it I don't think it came on when I plugged the new stereo in but maybe just didn't notice it, too dark to go and try again so will see at the weekend. I don't think it will come on without the optic cables but yeah good point and will sort that at the weekend when installing
Thu Feb 28 2019 7:32pm |
I don't know if you intend to use the analogue radio, but if you do, make sure the ariel amplifiers are being powered up via the blue wire |
Thu Feb 28 2019 7:58pm |
OK, yeah will be, from experience the DAB+ is almost none existant around here.
Thu Feb 28 2019 8:40pm |
The big one.
Thu Feb 28 2019 9:12pm |
right, yeah I got the usual blue auto ant wire on the adapter from Connects2 that is floating and I have a blue wire on the connector for the Xtrons units which has Back-car on the label which is also floating, you think these need to be connected?
Thu Feb 28 2019 9:20pm |
