Home > Maintenance & Modifications > 2014 Rear Pad Change Question
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Hi all,
I am going to change the rear pads and discs this weekend.
My car has the EPB TRW rear calipers.
I thought you had to retract the calipers by a certain operations of brake, throttle pedal etc. But a video online, a garage just had the parking brake off, disconnect calipers etc and fitted discs but then manual wound the calipers back like on a normal none EPB calipers and that was it???
Post #575954 Tue Feb 26 2019 7:17pm
PC76
if you have a GAP IID tool you can set the EPB to latching. this fully slackens the handbreak cable within the actuator.
you then need to fully wind back the break shoe adjuster which is located behind the disc and is accessed via a small aperture in the break disc. plenty of videos on you tube.
the combination of the brake pedal and EPB is to set the car in to EPB calibration mode, this allows the actuator and break pads to correctly re-adjust to the clearances after swapping the hand brake shoes. this is only required if swapping the shoes...
Post #575957 Tue Feb 26 2019 7:37pm
the_big_1
I don't have the tool.
There is no handbrake shoes. Mine has the calipers disc pads only. No appetites in discs etc?
Post #575959 Tue Feb 26 2019 7:39pm
PC76
you need to add your model to your signature....
Post #575960 Tue Feb 26 2019 7:41pm
the_big_1
Oppps missed that.
Added it but menu only goes up to 2013 and mine is a 2014 4.4 TDV8. Brembo fronts, TRW rears.
Hope that helps?
Post #575962 Tue Feb 26 2019 7:45pm
Disco_Mikey
Re: 2014 Rear Pad Change Question
the_big_1 wrote:
Hi all,
If the EPB is not put into "Service Mode" you will ruin the Motors...
Even with the EPB in service mode, the pistons still need wound back in
Post #575970 Tue Feb 26 2019 8:19pm
the_big_1
Hi ya,
How do I put them in service mode without the tool?
Post #575973 Tue Feb 26 2019 8:24pm
the_big_1
Here is the video where they do the change without any service modes etc.
Post #575984 Tue Feb 26 2019 9:48pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Looks like the video is for L320 sport rear and not L494. L494 has the servo motors driving the pads for handbrake activation. A totally different system to the LR3 and L320 which use the older top hat brake system for the handbrake
Forcing the pistons back wil wreck the servo motors in the L494 system so be carefull.
Take note Disco Mickey is the expert.
Regards
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #576004 Wed Feb 27 2019 9:51am
the_big_1
My brakes a 100% the same as the video and is a L494. The front and rear calipers are exactly the same as in the video.
Also, I have TOPIX for my car and it does say that there is a procedure to put them in service mode. I will try it Friday to see if it works.
Cheers all
Post #576005 Wed Feb 27 2019 10:03am
