![]() | Home > General > Faulty Parking Brake |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
Sounds like the module itself has a problem, but would need to be looked at to confirm exactly. I would certainly get it looked at as soon as possible and refrain from using it if you can,, it may save you a few quid. A module and cables will probably cost in the region of £500, if you leave it and it sizes on it may also cost you for discs and pads as well,,,, as happened to me! 2010 RRS, TDV8
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 ![]() ![]() ![]() |
It’s intermittent, and unfortunately I can’t avoid using the car. So I guess my best bet is to park on the flat at leave the parking brake off. Another forum suggested pulling the parking brake fuse... not sure why?! |
Using the car is not the issue, just the brake,, removing the fuse will stop inadvertent use of the brake until youhave the chance to have it looked at, but I would advise to look at it sooner rather than later,, it will only get worse. 2010 RRS, TDV8
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
When I had an issue with my EPB, I tried pulling the fuse only to find that the fuel gauge went to zero followed by the no fuel protocol cutting in. I would suggest that until you can get it sorted you leave it off, be sensible where you park, and stick a slab of duct tape over the switch (or you will automatically apply it). |
When mine was playing up I taped over the switch parked on the flat and with transmission in park all was fine. In the end pads and discs and an adjustment did the trick and no probs since. |
This is probably a very dumb question...
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
The park pawl is a fairly small thing and not designed for dynamic loads. It is supposed to hold the vehicle on a slope, however, so as long as you're gentle I don't see why it should be a problem.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Not such a great idea, the solenoid used to disengage the pawl when you take it out of "P" will struggle if there is a load on the pawl from the slope. Easy to damage the pawl, too. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Agree with the guys over the use of "P". This car weighs 2.5 tonnes and just picture that being held by a small piece of metal inside your gearbox.
Right, I think it’s time I booked it in for the repair.
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Have a read of this. It explains how it wrks, and you'll have an idea of what you're being charged for.
That’s useful - thank you.
You will get a good idea if you look at advance factors who are sponsors of this site. But before you shell out on parts have the system serviced and adjusted correctly. Dirt is a big enemy of the rear shoes, if yours has not reached the point of complete seizure maybe a good clean and correct adjustment is all you may need.. Once they sieze it's starts to get expensive. 2010 RRS, TDV8
Bad news...
