Home > Technical > Heating help Please
215m3
Heating help Please
Hi
I have a 2010 TDV6 and during the winter have kept the temp at 22 on the auto function on both sides. Today was a little warmer, so turned it down to 19. Now from experience with other models with the auto function the fan would kick in and you could feel cooler air out of the vents until 19 had been reached. With the RRS the fans did not kick in. Turned down to 17 nothing, 16 nothing, to low and the fans turned on full. As soon as I turned it up to 16 the fans cut off.
Is this normal? The air was cold, but it did not seem gradual. Can anyone offer an insight?
Thanks 2010 3.0 TDV6 RRS Overfinch GTS
1987 BMW E30 M3 2.4 Turbo
1990 BMW E34 M5 3.6 Trackcar
Post #575181 Wed Feb 13 2019 8:58pm
shepp
It is normal, on auto the fans will not kick in fully untill the engine has warmed. Enables the engine to warm quicker, rather than blasting cold air into the cabin. Once the engine/matrix can provide heat, the fans speed up to circulate warm air. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #575191 Wed Feb 13 2019 9:41pm
215m3
Ok will try if when the engine is up to temperature, thanks 2010 3.0 TDV6 RRS Overfinch GTS
Post #575194 Wed Feb 13 2019 10:00pm
