Home > In Car Electronics > Installing genuine lr reverse camera 2011 rrs
Weinel
United Kingdom 2011 Range Rover Sport 3.0 TDV6 SE Sumatra Black
Hi I have a 2011 rrs has anyone installed the factory reverse camera successfully & be able to tell me what parts I need & what’s involved? If I was to buy everything new from lr would it just plug in & work or would I need to some how get it activated? I have spoken to lr & they were not very helpful.
Post #574980 Sun Feb 10 2019 9:33pm
As you have a SE model I suggest before you do much to check to see if you have any of the relevant wiring in place, also has your rear spoiler got the aperture for the camera as if not then you would also need the spoiler as if I remember correctly L/R never did a spoiler with a blanking plug in the hole it was either there or not. Wiring in a camera is basically quite simple with the standard camera a live feed from the reverse light and a earth lead plus coax cable from camera to front screen, if you have the coax and power cable up in the roof at the rear there is a short fly lead available from L/R to connect the camera from the spoiler to the main roof harness.
Post #574984 Sun Feb 10 2019 10:26pm
Weinel
Hi mate thanks for a quick reply, the spoiler has the square bit in it that I can get cut out & fit the camera I got a price from lr for a camera & the bracket that holds it in the spoiler. I went on the head unit where you can see what is connected & for camera it says not installed I was hoping the wiring loom is the same just mine doesn’t have the extras plugged in. I will check 2moz & see if there are any bits to plug it in, am I right in thinking it will be in the head lining? If I do have that part of the loom is it just plug & play or does it need to be configured once installed?
Many thanks
Post #574986 Sun Feb 10 2019 10:47pm
Hi'
Would obviously save a bit if you can just cut the relevant hole in the spoiler, but you will also need to check the lugs are in the spoiler to clip the camera bracket into as the bracket clips in the spoiler and the camera then locates in the bracket. If you pull of the rubber tailgate seal where you see the rubber gaiters go from the body into the tailgate you should be able to flex the headlining enough to see if the cables are there, if you can't see enough you can pop a couple of clips that hold the lining up, but be a bit gentle when popping them it as they are located in a metal brkt. bonded to the headlining and quite easy to break the bonding.
Post #574989 Sun Feb 10 2019 11:06pm
Brit Plumber
If it’s of interest I have my spoiler etc off the car so I can replace my reverse camera. Even if you don’t have the relevant wires, the coax and cables are cheap to buy from LR but it does mean lots of interior stripping to locate the wires. See my thread on surround camera retro fit. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575517 Mon Feb 18 2019 7:50pm
Weinel
Hi thank you for the response, I have contacted LR who were not helpful at all for part numbers or anything really. Do you have any pictures on what I need to look for in head lining or part numbers to buy, I’m only after the rear camera not surround like you have done that is way over my head!! How do I get the CCF updated to allow rear camera if I ever manage to get that far?
Many thanks again
Post #575534 Mon Feb 18 2019 10:36pm
Brit Plumber
I’ll get some photos of various parts as an aid. I also have the wiring diagram which is a real must.
For the moment, check the back of your screen for the red port coloured connector in the below photo. This is the coax cable for the reverse camera or surround camera if fitted. If it’s not there, chances are there’s no coax and you will need to feed in the cable. This involves removing centre console, the sill cover and harness cover, the left side of the boot, the internal D pillar trim and pulling the head liner down a touch. Sounds daunting but you can get it stripped out pretty quickly.
Post #575538 Mon Feb 18 2019 11:59pm
Brit Plumber
A few photos
The white connector is for the camera (on its stowage point, I assume if the wire is fitted but not the camera, this is where it is stowed).
Post #575569 Tue Feb 19 2019 9:17pm
Brit Plumber
Wiring diagram
Post #575570 Tue Feb 19 2019 9:25pm
Weinel
Thank you, you are a star could I be really cheeky & ask you to email me a copy of the wiring diagram pls as I can’t zoom in on my phone just goes all blurry? How do I go about once all in getting it re programmed on the head unit so it knows the camera is there? Sorry for all the questions
Post #575579 Tue Feb 19 2019 10:34pm
You may need one of these, it's the jumper lead from camera through spoiler to main harness in roof/headlining, make sure you get LR016142 as the LR016141 is for the surround camera if I remember correctly. You may find it listed for a L322 fullfat but it is the one I used when I fitted a genuine A/B rear spoiler complete with camera to a pre-facelift HST. Wiring it in was quite simple. Reverse feed and Earth taken for N/S rear light unit, long co-ax cable with Fakra connectors off Amazon via a Gvif unit as I also fitted TV to the front screen, in your case you may not need the Gvif unit.
Post #575621 Wed Feb 20 2019 9:51pm
