Home > General (L494) > Ride comfort - perfect tyre pressure 21 ‘s
Bensrrsport
What is the prefect light load tyre pressure for an SDV6 (306) on 21’s for ride/handling and tyre wear?
I had the tyre pressure warning light come on the other day, so popped into my local Shell to check them. I noticed all tyres were around 3psi under what the door card recommends for light load. Having increased the tyres to the recommended pressure - the ride has definitely suffered!
Post #574597 Tue Feb 05 2019 10:59am
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
The recommended "light load" level is 34 psi for the front and 37 psi for the rear I think?
That's what I run mine at and yes, if yours were softer before, you would definitely notice the ride suffers but the MPG will improve...
Post #574599 Tue Feb 05 2019 11:41am
