![]() | Home > Technical > Heated front screen |
| rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150
More than likely the heating element is damaged in the screen I'm afraid. |
| Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394
So a new screen is needed? It does have a stone chip in the middle of the screen perhaps I could get it changed |
It's got power to it because it's working in part, but there is no way to repair it if the heating element is damaged in places. If you have windscreen cover on your insurance, it could be replaced if the screen was damaged by a bird strike or someone to that effect. Although it is unlikely to get replaced for a just chip........ |
Ok thanks for the advice |
| Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179
my screen is like that except the good bit is the drivers side, the rear screen doesn't work at all |
| Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33
Hi all,
That’s how mine started on one side now more or less the whole drivers side does not work, but the passenger side clears lovely |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117
If some strips take longer, then they take longer.
| syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412
I've had heated screens for 25 years or more (originally on Fords). They all do that after a while and the only resolution is a new screen. RRS MY17 SDV6 AB
The old ford ones lasted longer though |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
My old Focus Heated Screen lasted from the day I bought it in 2002 till the day I sold it for scrap in 2017, no loss at all. Not bad for a cheap and cheerful car. 2019 5.0 SC SVA (Current)
| SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 84
When I first got the current car, mine was the same. Turned out to be a fuse. Worth a check. Cheers, Stuart. RRS 2012 HSE 5.0 S/C Zermatt Silver. RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten Defender 2005 TD5 XS Black - Gone Freelander 2006 HSE Blue - Gone |
Really?? But the window does work just some sections don’t ! I will still have a check though |
My understanding is there is a fuse for each side so it could be that you have one bad side with dead elements but if the whole side is dead it may be a fuse. Of course, there could still be dead elements in that side too. Cheers,
