Home > Technical > Black smoke on acceleration
pre7amble
England 2006 Range Rover Sport TDV6 SE Giverney Green
Hi, I noticed a cloud of smoke when accelerating I have read on this forum and others that this might be a EGR fault. I have a Nanocom and decided to do some running checks and see what the EGR's were doing. The CSV file shows four readings for EGR items, two each for banks 0 & 1. One column of each is marked VLV and one column of each marked COM. I am assuming the COM is the ECU command and the VLV is the actual valve open position, in an ideal world the command and the valve position would be the same? The fifth column marked EGR throttle position I again assume is the ECU command for the butterfly valve in the electronic throttle? All these columns are marked %. So questions, what are they percentages of; position, total air intake, other? Whilst the command and valve position change with either accelerator or revs the EGR throttle position remains the same is this normal?
Something else; I notice from the CSV file the injectors are numbered in different cylinders I assume the injector number is the firing order? Again I am assuming the readings are in some form of pressure? Is it pressure of fuel in the injector or cylinder pressure? As two readings seem to be somewhat higher than the other four what is a reasonable difference. Indeed what is a normal reading for the 2.7 diesel engine.
Any information gratefully received, I have posted this on the Nanocom site
Richard.
Post #574302 Sat Feb 02 2019 11:50am
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
My 2012 does the same and there is a Land Rover Technical Bulletin that suggest a mod to the crankcase breather on certain vehicles with VIN’s between AA212145-DA814376 years 2010 - 2012.
Technical Bulletin LTB00487v6 3.0 TDV6 Excessive Exhaust Smoke.
Post #574330 Sat Feb 02 2019 5:36pm
Disco_Mikey
Black smoke is a boost leak, or too much fuel
Before you get way too far, start wwith the basics. The big turbo hose on the drivers side is very guilty for splitting, causing a lack of power And subsequent black smoke Thumbs Up
Post #574331 Sat Feb 02 2019 5:39pm
pre7amble
Hi, thanks for the prompt replies, my Vin falls outside of the suggested group but I will certainly look at the bulletin. I have checked the hose it looks OK. Would a split hose not cause black smoke every time you accelerate mine has only done it once. I was curious about the readings as a learning process in understanding my car more.
Richard
Post #574399 Sun Feb 03 2019 11:54am
MrGimper
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
I had black smoke under acceleration and it was that hose/downpipe that was split. Check underneath the hose near the top as mine had split there and wasn't obviously visible.
Post #574762 Thu Feb 07 2019 4:40pm
johnrambo
fuel dump
bad maps can cause this
Post #576704 Fri Mar 08 2019 6:04pm
Gandalf
Had the same ok normal driving but if I booted it got clouds of black smoke. Turn out the intercooler had split Censored If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #576716 Fri Mar 08 2019 8:36pm
Eskimo
I was suffering this on my 2.7v6, fitted an EGR blanking kit and no smoke, for £20ish it was a cheap and relatively quick and easy fix.
Since fitting the car is now running smoother, no black smoke and a lot less lag when pulling away plus the added advantage of a couple of MPG increase too.
Might be worth giving it a go. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #576721 Fri Mar 08 2019 11:05pm
