![]() | Home > General (L494) > 2018 model rear led lights |
| elaomar Member Since: 07 Mar 2018 Location: Milano Posts: 7
Hello,
| hario69 Member Since: 06 Jan 2009 Location: Teesside Posts: 68
Has anyone got a solution to the pre 2016 wiring problem - think it is a re-pin needed, but don't know how to do it....anyone?
Any ideas? |
| Damo1606 Member Since: 26 Sep 2018 Location: London Posts: 55
Regarding rear lights, you should have a look at the Glohh GL 5i lights.
| jaz9443 Member Since: 19 Jul 2011 Location: London Posts: 38
Fitted the 2018 rear lights to my 2014 car. They were plug and play and took no time to fit. All lights work including indicator...only thing is the indicator is not dyniamic sweeping type as they are on the actual 2018 models.
| nsmith4256 Member Since: 11 Feb 2019 Location: Leicester Posts: 2
I've been thinking of upgrading my lights. are these as good as they look? |
| pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413
Hi Guys old topic but thought id ask the question!
| SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60
Try this
yeah i sent the guy a message on how it works and if its a cut the wires job or a plugin adapter but got a yes I have to cut one wire on the lamp, Im guessing there might be a language barrier but there is no image or much detail so not sure I wanna throw £150 at it and find it doesnt work
Hi
| tsinc80697 Member Since: 10 Aug 2020 Location: Manchester Posts: 57
Bought mine from PowerfulUK as they have the sweeping indicator as well as cutting the side light when indicating which makes it much clearer.
| IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60
The DRLs on the 2018, front and rear, don’t come on until you select drive, probably to prevent them being on when you use remote start. The tail light goes off when the indicator is on, don’t know if that is legal. Agree with you about the idiots that drive around with front DRLs on and no rear lights especially in the dark. Ian 2018 Indus Silver SDV6 Autobiography normally towing a Buccaneer Cruiser. |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 322 |
Hey guys
| All times are GMT |
