![]() | Home > Maintenance & Modifications > L494 rear diff failure |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1199 ![]() ![]() ![]() |
Hi everyone,
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Surely if it was a common problem then we would have been hearing about it on this forum well before now. Possibly a bit of scaremongery and salesmanship from them. |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Rear diff was changed on mine at about 5k miles due to a vibration and oil leak. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4496 ![]() ![]() ![]() |
Ive replaced a 494 diff at 30k due to a whine...
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
My first L320 had a new rear diff at 6k miles but that was in 2009. I rejected that car for faults and was assisted into a new L320 which was brilliant. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
thought so as well -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 565 ![]() ![]() |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
To fix rear diff pinion leak (Common fault) with new bearing and seal as per the LR mod kit you need to split the diff. Chatted to Winchester gears and have the utmost faith in them doing it sucessfully.
Nice little 1 man job in garage completed circa midnight 1c garage axle stands and high lift trolley jack. Still happy today. Loan diff quiet no backlash and no leaks ๐๐
well done! |
Stuff Member Since: 29 Jan 2016 Location: In between cradle and grave Posts: 11 ![]() |
I have this problem. MY16 car with 65,000 km spewing oil over the rear diff and exhaust. Transmission whine and occasional hard shunt when driving. I stopped driving the car immediately I spotted the leak. |
sjoe, that sounds like quite a bad leak - mine only leaked a couple of teaspoons of oil and that was enough to warrant the diff being replaced. |
It's dripping wet all over, and has sprayed onto the off-side exhaust branch behind the diff (left-hand drive car). I guess the pattern implies a failure of a particular seal but that's beyond my knowledge. I have put a drip tray under the diff - I noticed the leak because a couple of table spoons of oil had dripped onto a tiled garage floor that I washed last week. I referred the car to the dealer earlier this year because of an intermittent violent transmission shunt when cruising. They reprogrammed the gearbox and returned the car - "no fault found". It's disappointing but it's normally a very good dealer, with a good principal and diligent workshop manager. Perhaps the diff was dry when they inspected the car. The dealer is closed indefinitely under the coronavirus "lockdown", and the diff may be empty by the time the car reaches the dealer, but perhaps not if the oil is being ejected under pressure when the car is in motion. No matter, this car is going to the dealer on a trailer. I guess a new diff will be required. Does anyone have an idea how much a new diff costs including fitting, before any goodwill contribution? It's a MY16 SDV8 Dynamic. I guess that LR will be quite hard-nosed whilst the global economy is tanking |
Got mine fixed last year under the approved warranty,they noticed the leak during a service & got me back in with a couple of weeks to get it fixed. Andy.
