![]() | Home > General > Dash trim clips |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5116 ![]() ![]() ![]() |
They are about £2.00 each from L/R FYC500040 some of them do tend to fly off never to be seen again. |
doyleywood Member Since: 09 Feb 2018 Location: Rossendale lancashire Posts: 18 ![]() ![]() |
thanks for that |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
I lost a couple which pinged off as you have experienced, when I replaced the radio. I found both of them quite easily as they had dropped down to where the centre console trim meets the carpet in the footwells. If you gently ease the plastic away from the carpet, you may be lucky and see them. Worth a try before you stump up the ridiculous price that LR or Powerful UK want for this tiny little piece of spring steel. |
As above, found one there today but I can’t find where it’s from! 2019 5.0 SC SVA (Current)
Have a look at this seller stuff, he may have something similar.
I managed to retrieve some using a magnetic flexible shaft pickup tool, just poked it in various inaccessible places to see if it picked any up.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
I used a few of them . They are not the correct shape on the ends, RR ones are flat where these are like bent round. It will result in the trim piece not going fully back. |
