![]() | Home > Technical > IID Tool - How to change to following please?? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5112 ![]() ![]() ![]() |
Step 1
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
It’s easy to select reverse follow me home.
You get the gap iid app on your phone from app store
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5114 ![]() ![]() ![]() |
Connect tool and wait for main menu to load, go down list to CCF configuration touch on that it will then load confirmed list, touch on that it show ecu list on left, touch BCM Body Control will then show list on right of all the files in the BCM they are alphabetical so alarm chirp is close to the top, touch on it a screen will come up with enable-disable option on it touch enable, if you then go back to the file list go down to "F" you will find the "Follow me home reverse" setting just enable the same as previous, as you exit it will ask you to confirm changes just touch yes and wait for it to change the settings and follow the on screen instruction. It really isn't as daunting as it appears, I do prefer to use a ipad rather than a phone though simply as you have a bigger display. As said though make sure battery is well up just to be sure.
At the final stage when you tell it to make updates to whole Car goes a bit mad. This is normal.
Yeah, have to admit the first time you see it do that you do think to yourself what the |
I don’t know about anyone else’s car but my clock always re-sets to 12 o’clock.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Really stoopid question but can the IID tool set the clock time on the dash? Having removed the OE stereo, the time on the dash starts from when the battery is connected and is not changeable obviously.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
You could disconnect the battery and reconnect it at midnight |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Brit, can you send a link to the VMC2 tool i would like to know the differences. |
