![]() | Home > Technical > Telestart T91 FBH - Help needed |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
Yes there is 2 settings than need changing in the ccf park heating with remote and park.heating with fuel fires heating. I think from memory.
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
You need to edit the CCF and the EUCD
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Thought it was my error!
Yes you can ๐๐ |
Is this right?
You have timed climate disabled |
So apart from enabling 'Timed Climate' which I'll go and do now everything is right for times and using the remote? Cheers Laurence. |
everything else seems to be right laurence |
Cycle the ignition twice,,,? this is where I might have gone wrong before and got all those faults come up? so switch the car off after settings are changed (leave the IID Tool plugged in or not?) then press button once so ignition on then press button again for ignition off. Once again for ignition on then off then I'm good to start? |
yes leave the iid tool in (it should tell you to cycle the ignition once the ccf has been uploaded anyway
Now the remote is working.. |
This what Iโve set too
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Just a guess, but could it be due to the outside temperature, doesn't the FHB only fire up once the temperature drops to a certain level. |
I think you have your ccf settings right now |
