![]() | Home > Maintenance & Modifications > Heater not blowing hot. 55 plate rrs |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Are both sides the same temperatures? |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 ![]() ![]() |
Hi, yes both sides seem same temp. If i turn Aircon off then it definately gets warmer. DT accross the flow and return is narrow so dont think its blocked heat ex |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Sounds obvious, but check that your pollen filter isn't blocked. If the fan can't blow through it, then no heat !
