Home > General > RRS 3.6 V8 diesel or 4.4 V8 petrol ?? |
I have the supercharged petrol engine so i am biased but as far as i am aware they are more reliable but still have a few issues |
Thu Jan 03 2019 10:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
4.2SC.
Thu Jan 03 2019 11:07pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I'm biased too!
Fri Jan 04 2019 1:26am |
I think you’re limiting your self to the oldest RRS when looking at the 4.4, at least if you look st the 4.2 you can buy a car that at its youngest could be 10 years old.
Fri Jan 04 2019 10:04am |
Mart Member Since: 03 Jan 2019 Location: Sheffield Posts: 15 |
Wouldn't it be cheaper to fix 4.4 one on 4.2 supercharger itself cost 400+ ... Don't mind repairs but don't want to put fortune into it all the time , and if it runs fine I might think of converting it to LPG but that's a long term , in there any 4.2 running LPG here ?? |
Fri Jan 04 2019 1:56pm |
SC are fairly reliable though.
Fri Jan 04 2019 3:24pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
I have the 3.6 V8 and as brit plummer says, turbo's are an expensive item,,, I'm keeping my fingers crossed!. Most other things are par for the course no matter what model you get,,, front arms, wheel bearings, brakes. 2010 RRS, TDV8
Fri Jan 04 2019 5:46pm |
My supercharged has a lpg system and a lube kit and runs with no issues that i am aware of |
Fri Jan 04 2019 7:21pm |
Are you getting any faults coming up on dash when u running LPG ?? Just summat I've seen on other forum |
Fri Jan 04 2019 10:46pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
I have a SC with lpg / lube kit also. Runs OK. No dash lights.
Fri Jan 04 2019 11:24pm |
No faults now but was getting the P0172 P0171 code but found that to be the oil filler cap not sitting on properly on mine and i think that's the most common fault that shows which is lean bank 1 and 2 |
Sat Jan 05 2019 3:04pm |
The early ones can also have the aux pump for the supercharger wired the wrong way round so the pump actually runs back wards but easy enough to change the pump yourself and costs about £100-120 for the pump that puts it into limp mode when the spirited driving mode starts which is quite often lol |
Sat Jan 05 2019 3:07pm |
yeah the lean/rich codes codes can occur without LPG |
Sat Jan 05 2019 4:08pm |
Yeah but quite surprised that it was so simple on mine to get rid of the codes but took a while to find |
Sat Jan 05 2019 4:40pm |
