![]() | Home > General > Garage Door Opener |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 477 ![]() ![]() |
My 2012 Autobiography has it
I had found the American ones but I wasn't sure that they were on the same frequency as us. The UK one has the high beam assist camera on it so is silly money.
Does the High Beam Assist need anything else apart from the camera on the rear view mirror (+ enabling in the CCF)? 2016 Black SDV8 Autobiography
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5103 ![]() ![]() ![]() |
New Zealand Tim, New Zealand. ![]() Several listed but appear to have been superseded to LR024335 but don't bother with new over £600 inc.vat from L/R. Needs to work on 433 MHz frequency in UK. Have high beam assist but never use it to many things affect it, highly reflective road signs for example. Just another L/R gimmick that nearly works. Cheers Col |
Thanks Col,
Hi, not sure on that one, will have a look at some wiring diagrams etc. later, as just off to the beach 29 degrees here at the minute. |
Thanks Col,
I’ve turned mine off to, I got fed up of being flashed because it was to slow to react, especially on corners. 2019 5.0 SC SVA (Current)
