Home > Technical > Webasto FBH
Page 1 of 3 123>
Buster007
Webasto FBH
MY2012 RRS has a Webasto FBH front near side under the bonnet (pictured below) no timed controls on the ‘Extra Settings’ on the menu screen inside?? Where are the timed controls to switch in on to warm the car inside on cold mornings..Brrrrrrrr!!
 Cheers Laurence.
Post #571869 Sat Dec 29 2018 1:21am
Bardley
You'll need that activating in the Car Configuration File- CCF. There are a few guys on here that can do that for you, and and sure they'll be along soon..
Also be aware that you cN get a remote gob to do this, and even an aftermarket unit made by Altox. This allows web based timed/immediate switching and uses a monthly SIM card.
Have a read here on the Disco4 forum..
https://www.disco4.com/forum/webasto-fuel-...-vf96.html 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #571870 Sat Dec 29 2018 6:23am
Buster007
So I can just get a remote and job done instead of all that parafinalla of wiring in a unit for timer controls? Cheers Laurence.
Post #571875 Sat Dec 29 2018 9:29am
Bardley
No.
The on screen timer can be activated in the CCF. That'll give you pre set FBH control.
If you want the remote, that needs activating too in the CCF, but is usually just 'switched on ready' when the timer setting is setup.
If you want remote activation, that's a plugin unit in the rear area, straight into an in place at build loom. Easy fit... it has a little box, an aerial, and that's it.
Look thro the link i sent and you'll find a few guys that can do all that for you.
It's a commin add on for D4 owners. 2011 MY D4 HSE
Post #571876 Sat Dec 29 2018 9:48am
Buster007
Thank you Thumbs Up
All seems too easy I was trying to make a big job of it..... Laughing
I’d be interested to hear from anybody that can do this for me in terms of the software etc Cheers Laurence.
Post #571877 Sat Dec 29 2018 9:55am
TubaPlayer
Re: Webasto FBH
Does this mean that you've finally found one? Very Happy 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571878 Sat Dec 29 2018 10:05am
Buster007
It certainly looks that way... Thumbs Up I’ve done the deal hoping to collect next week I’ll put pic’s up. It’s 12 plate Lux Pk black with black leather, white contrast stitching a credit to the last owner in mint condition! I got almost all the extras I wanted apart from heated steering wheel and black roof lining. I’m interested to know how to activate the FBH, my last 13plate Black Edition had one as this one has but on the black edition it was already set up on the menu to work. It seems on the 12 plate they put one in but never put the software on the car to use it???? Very strange..... Thud Cheers Laurence.
Post #571882 Sat Dec 29 2018 10:32am
TubaPlayer
I think timed climate was an option on most models but standard on the Black Edition. The FBH still works when needed even without the timed feature. 2016 Black SDV8 Autobiography
Post #571883 Sat Dec 29 2018 10:41am
Bardley
It works when the temp. Is low and the engine calls for it to aid engine warm up.
The timed climate is a binus feature to pre warm the interior. It will also activate the internal fans to cirxulate the air.
Frosty mornings are no longer a problem if you get the system on about 20mins before leaving. Windows will clear of frost.
The LR /Webasto two button on/off remote is the one i have fitted, and can vouch for it's efficiency. 2011 MY D4 HSE
Post #571885 Sat Dec 29 2018 10:59am
Bardley
The plip is a small unit with on and off buttons.. 2011 MY D4 HSE
Post #571886 Sat Dec 29 2018 11:03am
Bardley
This is the plugin unit..
 2011 MY D4 HSE
Post #571901 Sat Dec 29 2018 12:33pm
Buster007
So I need this unit ^^ above^^, somebody activate the in Car Configuration File - CCF and a remote... Thumbs Up
Is this any good?
https://motor-roam.co.uk/l322-range-rover-...-10-pounds Cheers Laurence.
Post #571947 Sat Dec 29 2018 7:22pm
Bardley
That unit is just a WiFi switch, so I don't think that will work on your car. The Webasto needs a signal, not just a live feed to start.
Best bet is to contact one of the guys that fits the specific units.. either the Telestart or the Altox. They are literally plug and play once the CCF has been edited. It's no magic with the CCF and the correct tool to do it.
Most Independent LR garages will do this.
The telestart units occasionally pop up for sale in the forum.
By the time you've messed with the other wifi unit you've posted, it may well work out more expensive. 2011 MY D4 HSE
Post #571957 Sat Dec 29 2018 9:30pm
shepp
Buster check out the link from bodsy
http://www.rrsport.co.uk/forum/topic46083.html
I got the remote and module, just plugs in the boot. I have the iid tool so I activated it myself. Pre heat is the best thing I ever bought, works at up to 1km away. I bought my kit from bodsy, took only a couple of days to arrive.
It's well worth purchasing a ctek charger and the tow electrics adaptor, to ensure you keep the battery topped up.
 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #571971 Sun Dec 30 2018 10:44am
TubaPlayer
I have made up a ctek adaptor, it's really handy Very Happy 2016 Black SDV8 Autobiography
Post #571991 Sun Dec 30 2018 4:24pm
Page 1 of 3 123>
