![]() | Home > Technical > Indicator |
| TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189
Are you sure it's the full beam? It is more likely to be the cornering light (it has a separate bulb in the headlight unit) 2016 Black SDV8 Autobiography
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
there's a bulb in the reflector below the indicator
| Tomascole1 Member Since: 26 Jul 2018 Location: Gwent Posts: 104
No it's definetly full beam I have the blue full beam light appear on the dash |
probably faulting indicator stalk then as an easy and cheap attempt to fix |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Does the full beam come on with the Baz lights? If not I’d go with stalk to. 2019 5.0 SC SVA (Current)
The with baz? |
Bloody auto correct.... Hazard lights 2019 5.0 SC SVA (Current)
No just indicating left it's strange |
How hard is it to change an indicator stalk?? |
Before you do look at changing that, maybe try disconnecting the left front indicator and see if the full beam comes on still, then repeat with the rear and then the door repeater just to rule out a bad earth (although I suspect only the front left if any, would effect full beam).
It's strange because when I put full beam on it doesn't seen to click on if you know what I mean is it supposed to? Merry Xmas to all by the way |
well if the stalk doesn't feel right, and indent onto main beam, that is a good reason to change it |
So there's supposed to be an indent into it?? |
your meant to push the stalk back (to the dash board) and it stay there in main beam mode, just like 1970's cars.
| All times are GMT |
