![]() | Home > My Range Rover Sport > Diesel heater webasto |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
Unless you have the optional park heating, the FBH (fuel burning heater) is an entirely automatic device. It's used when the external temperature is below about 6 deg C (some are higher than that it seems) and where the coolant temperature is below a certain threshold. I.e. if the engine is cold/cool and the ambient temperature is cold.
DeeWee Member Since: 04 Dec 2018 Location: Plymouth Posts: 26 ![]() ![]() ![]() |
Thank you so much for the reply. Very very helpful, I'm glad it's not a case of operator error. I was thinking how do I turn this thing on but now I know I have to buy the additional kit I will.. 👍🏻 😁 |
Do a search on the forum and you should find a recent-ish thread about the kits etc. |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
Worth checking on topix what your car is supposed to have. I just needed to buy the remote fob and it worked. Merc C220 estate Sport AMG
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
How do you know if you've got what you need to just add the fob? 2016 Black SDV8 Autobiography
I can't find the the thread on the forum but there's a receiver module in the drivers side boot cubby. If you have it, then you just need the fob to transmit to it. The thread explains how to pair the fob (from memory, you just have to remove and replace a fuse). Merc C220 estate Sport AMG
Here you go - http://www.rrsport.co.uk/forum/topic46822....te+fob#end Merc C220 estate Sport AMG
A big thanks to all who replied with their help. |
