![]() | Home > Technical > Power failure! |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
I used to get this from time to time in my Jag XJ TDV6, I changed the Battery and this stopped it for a while. After it happened with the new battery I used to put it on charge regularly and that seemed to reduce it. 2016 Black SDV8 Autobiography
gwdalba Member Since: 03 Sep 2010 Location: Nairn Posts: 46 ![]() ![]() ![]() |
I can only pray and hope it's something that simple but I really fear the worst reading online all the cr*p with crankshaft failures! RRS 3.0 SDV6 HSE 2012 Santorini Black
We had a similar problem with a Customers D3 ended up being the fuse next to the battery + terminal. The wire had rubbed through on the engine block and shorted blowing the fuse. I hope this might set you in the right direction 2008 G4 RRSport TDV8 current
Not good news today. Engine failure due to the crankshaft issue |
