![]() | Home > Technical > RRS oil level |
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656
Are you following the correct procedure |
| Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479
Try This one..
| blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66
Ok thanks I'll try that. |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5154
Make sure you are not resting your foot on the throttle pedal slightly either or try putting your toe under it and lift the pedal very slightly when checking.
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
Should be in the owners manual |
| All times are GMT |
