Home > Maintenance & Modifications > MOT advisories: No reading on smoke test??
Buster007
On my long quest to find a well looked after, good condition 2013 RRS I may have found one ironically through a friend. Anyway on checking all previous MOT's the last one done in August 2018 had an advisory ' no reading on smoke test' is this an advisory, a fault or just a note? Should I be concerned? Cheers Laurence.
Post #570649 Fri Dec 07 2018 8:25pm
Autobiography1969
Doing a quick search it looks to be an advisory,,
But to be sure it would be worth phoning your local garage MOT station
and asking them to confirm,,
Also found this..
diesel have a smoke test using a emission equipment. The limit hasn't been changed for as long as ive been in the trade and cars with dpf produce so little "smoke" that it doesn't detect its even having a emission test, the meter wont read a reading that it can pick up.
That is why its advised because no print out is available for records for the tester when the minister turn up it can be stated why there is no record of a emission test when the minister turn up.
Sounds like its as clean as a whistle..
But still worth making the phone call to confirm.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #570652 Fri Dec 07 2018 8:48pm
Buster007
I'm thinking maybe get the current owner to get another smoke test done at an MOT station and a print out before buying? Cheers Laurence.
Post #570656 Fri Dec 07 2018 9:45pm
Tyrefitter
If it says no reading on smoke test that means the emissions where good,,I now have a dongle that plugs into the obd so even if I don’t get a reading it gives a printout,,,so basically it’s nothing to worry about as it means their wasn’t enough smoke to detect a reading. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #570658 Fri Dec 07 2018 10:26pm
Buster007
Thanks Andy... Thumbs Up Cheers Laurence.
Post #570664 Sat Dec 08 2018 12:02am
